Policy change~Image sizes
Postby Ye Olde Republic » Mon Aug 23, 2010 6:01 pm
Hello members, classic-castle administration has decided to increase the maximum image size you are allowed to put in your posts. With the recent changes at Flickr, a very popular place for image hosting, of their default size of 'medium' images being 500 pixels wide you may now use that setting. For you Flickr users, they even now have a handy bbcode that you can just cut&past into your posts; it can be found in the drop down menu "Share" right above your picture. Images 500Wx400H may now be used. One image of this size per post so please choose carefully. Four images per post should be enough so make sure if you have a lot of pictures to show off, make sure you link back to the gallery. The old rule still applies to posts with multiple images.
To simplify:
1. Your main image may be 500 pixels wide x 400 pixels high or smaller.
2. Additional images must be thumbnail images, as before.
3. Your post may contain only four images total.
The old rule can be found in the TOS here and here:
Be considerate of transfer speeds. HTML is currently disabled, but if it is enabled at a later date, the use of embedded objects, java and javascript are not welcome. Also, do not use overly large signature images or post overly large images in your post. An ideal signature image is 100 pixels high or less; images in a post should be 400 pixels high or less. Please do NOT include the image in your reply. These provisions will help keep Classic-Castle.com running quickly and efficiently.
Thanks and enjoy.
Trevor
flickr
My blog
Ye Olde Republic
Marquis of Brique
Marquis of Brique
Re: Policy change~Image sizes
Postby Sir Nelson » Mon Aug 23, 2010 9:54 pm
Ye Olde Republic wrote:To simplify:
To clarify, what if your main image is 'portrait oriented'? Will you allow 500p high x 400p wide, or smaller?
Sir Nelson
Man-At-Arms
Location: Where Lords go, before they get their revenge... cause YEAH, it is coming!
Postby Ye Olde Republic » Mon Aug 23, 2010 10:42 pm
Thanks for asking, we'll take this under advisement.
Trevor
flickr
My blog
Ye Olde Republic
Marquis of Brique
Marquis of Brique
Postby Ye Olde Republic » Mon Apr 18, 2011 9:42 am
A reminder to please not take advantage. It's not cool to put more than the allotted pictures in your posts and then tell us that you thought it was OK because you weren't told to edit your post right away. "Playing dumb" or feigning innocence will get you nowhere. It is your responsibility as a member here to know the written rules and guidelines. We understand that there are the unwritten ones and those take time to come to know and fully understand.
Trevor
flickr
My blog
Ye Olde Republic
Marquis of Brique
Marquis of Brique
Postby Knight Man » Fri Feb 03, 2012 12:04 pm
So how many images can you post? I need to post eight for a set review is that ok? ~KnightMan~
Romans 8:37~ Yet in all these things we are more than conquerors through Him who loved us.
Joshua 24:15~ ...But as for me and my house, we will serve the Lord.
Image My Flickr My sets
Knight Man
Postby AK_Brickster » Fri Feb 03, 2012 1:10 pm
Usually you get to post 2 images and provide links to the rest. Exceptions are sometimes made, but if you are going to post 8, they probably should be as small as possible.
Image Image
Plastics make it possible! (BrickLink) - - - My Flickr Stream
Gong Farmer Overseer
Postby Bluesecrets » Fri Feb 03, 2012 3:27 pm
You post two and link to the other images or you link to the folder or set. Please do not post more than 2 in each post.
~ Brickshelf~Flickr~
Postby lord_of_orks » Sat Feb 04, 2012 6:05 pm
I don't mean to be a pain, but in this post you said that we we're allowed 4 images or less, has the policy changed since then? Could you please clear this up for me.
Image brickshelf flicker
one for all! all for one! every man for him self!
lord_of_orks
Postby Bluesecrets » Sat Feb 04, 2012 8:35 pm
Oops, it is 4. I misspoke above. I do apologize. Please do click the link in that post for specific rules. Thank you.
Postby Knight Man » Tue Feb 07, 2012 3:21 pm
Thank You. ~KnightMan~
Knight Man
Return to Administrative
