Avatar Issues
porschecm2
Avatar Issues
Post by porschecm2 »
I deleted what was my current avatar earlier, to install a new one I had just made. However, it won't let me upload my new one, or any old ones now. The file size and resolutions are fine; even previous avatars I've used here before won't work. I get a list of error messages in what I assume is the PHP code when I try to upload directly from my PC, and when I link to the file at brickshelf, nothing happens whatsoever. Any suggestions?
Cm2
[img]http://www.brickshelf.com/gallery/porschecm ... onal.1.png[/img]
Think twice. Post once.
Constructum excellentia!
Shurtugal
Location: On the Albertan Prairies, listening to some slow country music
Post by Shurtugal »
Well, I can't help you, but I have a question of my own. I can't get a picture that is 120 by 120 and keep to the 10 MB limit. I need to make the picture like 39 by 39 before it is less than 10. I've wrecked my best wrestling pic to try to figure this out.
~Andrew C.
[url=http://www.mocpages.com/home.php]MOCpages![/url]
Eka ai fricai un Shur'tugal! I am a Rider and a friend!
TheOrk
Post by TheOrk »
Shurtugal wrote:Well, I can't help you, but I have a question of my own. I can't get a picture that is 120 by 120 and keep to the 10 MB limit. I need to make the picture like 39 by 39 before it is less than 10. I've wrecked my best wrestling pic to try to figure this out.
For the record I have the same problem. :wink:
stewa_sk8
Post by stewa_sk8 »
I have the same problem with uploading ...
:cry: :?
Drucifer
Post by Drucifer »
See this thread (specifically my post, which be the second one down)
viewtopic.php?t=5617&start=105
about removing the EXIF data from your images. That will probably help you guys to get down to the size limit.
porschecm2 is your theme set to the standard CC blue theme or the default phpBB theme? I remember reading something about admins having problems with the standard CC theme, so maybe that causes problems with avatar uploading. :?
[url=http://www.mocpages.com/home.php/1994]MOCpages[/url], [url=http://www.brickshelf.com/cgi-bin/gallery.cgi?m=avanper]Brickshelf[/url]
porschecm2
I tried changing the theme, but to no avail. I guess for now my avatar will reside in my sig.
Cm2
Fry_slayer
Post by Fry_slayer »
This has been mentioned before
viewtopic.php?t=7707
Do not try to change avatar before the issue is fixed, or you will be forced to use standard avatar or non
[url=http://www.brickshelf.com/cgi-bin/gallery.cgi?m=Fryslayer]Brickshelf[/url] | [url=http://brickgamers.blogspot.com/]BrickGamers[/url]
Troy
King Mnementh the Bronze
Post by Troy »
Try uploading your avatars now. I think that I have corrected the issues with it. Atleast I was able to upload a new avatar and it worked.
Let me know if you encounter any problems.
Troy
Visit Troy's Surplus LEGO
http://www.bricklink.com/store.asp?p=mnementh
Fry_slayer
Yeeeesss! All hail the King! (again)
TheOrk
Post by TheOrk »
Fry_slayer wrote:Yeeeesss! All hail the King! (again)
Huzzah!
8)
Avatar by Graynar
porschecm2
Yay! Thanks! :D I've kind of gotten used to my little guy down there though...I'll have to find something else to put there...
Cm2
Athos
Councilor of the Realm
Post by Athos »
Yay! I'll add my voice to the chrous of well-deserved thanks.
Jake, of the Palace Guard
Post by Jake, of the Palace Guard »
As will I!!! :D
E of Alshire
Post by E of Alshire »
Well, now I feel as if I need a new one...
Thanks a million!
