Lego Catapults
Lego Catapults
Postby Frank_Lloyd_Knight » Sat Aug 14, 2010 5:17 pm
Which Lego catapult flings a brick the farthest?
Frank_Lloyd_Knight
Re: Lego Catapaults
Postby veevers24 » Sat Aug 14, 2010 5:19 pm
Wouldn't that greatly depend on how hard/fast you hit the handle?
Probably the spring loaded ones though
veevers24
Newbie of the Month
Re: Lego Catapults
Postby quaraga » Mon Aug 16, 2010 3:45 am
sounds like some science is nesesary, how about you get a weight, a few catapults, a universal projectile, and a yard/meter stick. then applying only the weight of the weight measure how far the projectile goes.
and what spring loaded catapults?
He who thinks you should look at the box that says "Quaraga" if you want to find out his username (about as useful to you as his real name). he only wants you to look so he can laugh about you looking there because he's a total smart...
quaraga
Total n00b
Total n00b
Location: roflysst (rolling on the floor laughing, yet still somehow typing)
Re: Lego Catapults
Postby veevers24 » Wed Aug 18, 2010 4:39 pm
I was referring to the spring loaded projectile firing thing that came with some Knight Kingdom I sets
veevers24
Newbie of the Month
Re: Lego Catapults
Postby Frank_Lloyd_Knight » Sat Aug 21, 2010 3:51 pm
quaraga wrote:sounds like some science is nesesary, how about you get a weight, a few catapults, a universal projectile, and a yard/meter stick. then applying only the weight of the weight measure how far the projectile goes.
What logical thinking. I took your advice, and measured the two catapults that I actually do have. These were from set numbers 6030 and 6193. I made a 2 ounce weight out of a lump of modelling clay wrapped in aluminum foil. I lined up a couple of yardsticks from the fulcrum of each catapult and dropped the weight from a height of 12 inches -- using a single 1x1 cylindrical brick for ammunition. It wasn't easy to get particularly consistent results, so I took the average of the five longest shots. Here are the results.
Image#6030: 50 inches.
Image#6193: 62 inches.
Since 6193 was so easy to adjust, I moved the lever arm back one notch (from what is shown in the official instructions), and this increased the range to 70 inches. But I didn't attempt to make the same adjustment for 6030. I still think it would be interesting to compare results if anyone else has any other catapults they could test.
Frank_Lloyd_Knight
Re: Lego Catapults
Postby JoshWedin » Sat Aug 21, 2010 5:57 pm
Frank_Lloyd_Knight wrote:I still think it would be interesting to compare results if anyone else has any other catapults they could test.
This was interesting. I'd be interested in that too. Now you are almost getting me to rebuild some of older sets....almost. ;)
Image The Brothers Brick
JoshWedin
Chevalier de Chèvre
Chevalier de Chèvre
Re: Lego Catapults
Postby Frank_Lloyd_Knight » Sat Aug 21, 2010 8:13 pm
JoshWedin wrote: Now you are almost getting me to rebuild some of older sets....almost. ;)
Do it! The world wants to know... Or at least I do.
Frank_Lloyd_Knight
Re: Lego Catapults
Postby Legoorci » Sat Aug 28, 2010 9:42 am
I would say it's the vikings catapult. A friend of me owned one and it could fire very well!
You can see my MoCs on my Flickr Account and you can see them also on my Blog where you also can read the stories behind the MoCs...but in german.
Legoorci
Re: Lego Catapults
Postby quaraga » Tue Sep 07, 2010 3:26 am
I concur I had that one and it worked pretty well.
the one piece catapult (like in kcs) probably sucks
quaraga
Total n00b
Total n00b
Re: Lego Catapults
Postby TheFlarbar » Fri Oct 29, 2010 6:06 pm
I found that the catapults with wheels rolled too much to hit their target. :mad:
TheFlarbar
Re: Lego Catapults
Postby JoshWedin » Fri Oct 29, 2010 9:16 pm
TheFlarbar wrote: I found that the catapults with wheels rolled too much to hit their target. :mad:
Did you try holding them still? I've never had this "problem".
JoshWedin
Chevalier de Chèvre
Chevalier de Chèvre
Re: Lego Catapults
Postby Frank_Lloyd_Knight » Fri Oct 29, 2010 9:44 pm
I can't remember -- I think I took the wheels off of the one I tested, and attached it to a base plate.
Frank_Lloyd_Knight
Re: Lego Catapults
Postby rogue27 » Sat Oct 30, 2010 1:18 pm
On most of the recent catapults, the arm swings too far and tends to fling the brick into the table unless you put in a stopper.
rogue27
Re: Lego Catapults
Postby SevFalcon » Sat Oct 30, 2010 4:36 pm
rogue27 wrote:On most of the recent catapults, the arm swings too far and tends to fling the brick into the table unless you put in a stopper.
Great suggestion and makes perfect sense. I like the new catapult in the Outpost Attack set but it suffers from this problem....
SevFalcon
Re: Lego Catapults
Postby Velliscig » Thu Dec 02, 2010 5:37 am
Perhaps just place a "wooden" wedge brick underneath the back wheels? You gotta think, what would a minifig do, you know.
Velliscig
Return to LEGO Castle Sets
