The first castle ive done in a year
- Andrew_sension
- Peasant
This is my castle that houses black falcon soldiers and thier king. Just looking for some coments.
http://img5.photobucket.com/albums/v14/ ... les002.bmp
http://img5.photobucket.com/albums/v14/ ... les003.bmp
http://img5.photobucket.com/albums/v14/ ... les004.bmp
http://img5.photobucket.com/albums/v14/ ... les005.bmp
"Acetominophen you see the medicine, oh girl!"
- Andrew_sension
- Peasant
- Formendacil
- Andrew_sension
- Peasant
If you want more wall pieces, check out Bricklink, and this store called Bricks4you. It is in Denmark, with a minimum order of $100.00 USD, but if you do a group order (thats what I did) it works well. He has really good deals, I was able to get 40 wall pieces for $15 USD!
As for the MOC, I like the way it opens. Well done.
- Andrew_sension
- Peasant
Nice little MOC there! It reminds me very much of a LEGO set!
About the wall pieces - I used them for a bit, then realized that for about the same price as a wall piece you can usually get all the pieces you need to make an equal amount of wall out of bricks. And personally, it looks much better.
[img]http://farm1.static.flickr.com/176/41213568 ... 65c9_o.gif[/img] [url=http://www.classic-castle.com/forum/viewtop ... 540#103540][img]http://www.brickshelf.com/gallery/j1a3l5/Mi ... banner.gif[/img][/url]
- Dragon Master
- jamitjames
- Gentleman
Yes, it would look alot better with out the wall pieces. As for the MOC, it does look like a LEGO set (don't know if thats a good thing.... ).J1A3L5 wrote:About the wall pieces - I used them for a bit, then realized that for about the same price as a wall piece you can usually get all the pieces you need to make an equal amount of wall out of bricks. And personally, it looks much better.
[url=http://radio.laml.org/]LAMLradio: LEGO Talk Podcast[/url]
- Dragon Master
- Andrew_sension
- Peasant
- wlister
You cannot purchase the same amount of new bricks in old light gray for the price you can get new castle wall pieces. That may have been the case 18 months ago, but old light gray in decent quantities is getting harder to come by and the prices are going up.
Back on topic, I like your MOC, the hinge opening looks good, it has 4 walls which makes it better than most sets produced by TLC. If there was one thing I would change, it would be the door piece. That same piece is available in old light gray in set #4705 Snape's Classroom. That set can still be found in a lot of areas and usually for much less than full retail. The tan just doesn't fit. The rest I like.
- Formendacil
