Small Bridge
- The Josh
Small Bridge
My 100th Post!!
I figured I should make this one special, so I'm posting an MOC, a small bridge:
http://www.brickshelf.com/cgi-bin/gallery.cgi?i=841581
PTMWYT
I know it's not much, but I'm saving the real stuff for brickfest . I won't be able to respond to this post, for I'm going away for the next two weeks. I be back soon!
-The Josh
PTMWYT
-The Josh
- Formendacil
I know you said you can't respond, but maybe somebody else knows this...
Is the bridge sturdy, or would the beams fall down if you tried pushing a minifig down onto one of the studs?
Regardless, it looks very nice.
- porschecm2
Re: Small Bridge
Congratulations.The Josh wrote:My 100th Post!!
-The Josh
And that's a great little bridge. Simple, but very imaginative, using an approach I've not seen before. I like it a lot. Must copy.
Alan
I was always wondering about that. I called it Mock, but I think he uses it as M.O.C. since it stands for something. But S.N.O.T. just doesn't work. Neither does P.O.O.P., B.U.R.P., etc.Formendacil wrote: (BTW, do you is MOC pronounced em-oh-see, or moek/mock? Not that it matters, but Josh's use of an MOC looked weird, because I always seem to use moek. And I've heard mock. Just a weird question.)
Great bridge, I really like how you made it curve. Awesome.
- Lord_Of_The_LEGO
- Earl of Wells
Now that is one cool bridge! Yet another idea for me to steal...
I always pronounce it 'mock'.Formendacil wrote:(BTW, do you is MOC pronounced em-oh-see, or moek/mock? Not that it matters, but Josh's use of an MOC looked weird, because I always seem to use moek. And I've heard mock. Just a weird question.)
That bridge is really neat! I too have seen it done to line the inside of an arch, and I even tried it once, without success. However, I'll have to see if I can build this one successfully. The picture is much clearer as far as how the pieces need to be arranged than the one I was trying to copy before. Thank you for posting this!
- Robin Hood
My guess is that it holds up quite well. It utilizes the same principle that an actual stone arch does, with the stones pressing against each other to transfer the force down into the support or the ground. Those appear to be the one-piece black arches, so unless they detach from the green plates they should be fine under normal use. If it needed to be strengthened, the whole assembly could be attached to a baseplate. The only potential weak point I can see is if a rotational force is applied to one of the plates in the deck, causing it to slip due to the gap at the top of each consecutive set of plates.Robin Hood wrote:Yeah its great, but I have the same question, how is held up, or will it just fall apart if weight is put on it.
P.S. Don't ask a question about the structural integrity of a bridge when there's a civil engineer around to (try to) explain it!
