Personally, I would go with blue. I believe that is the default color unless you changed it, so it is probably the most recognizable. You are correct about the green being dark. That could get expensive and it blend into the landscape quite a bit. But it is really up to you guys.AK_Brickster wrote:Josh, I think we are going to go w/ either green or blue for the Teutons. I'd prefer green, aesthetically, but maybe blue would be easier since the green from the game is more along the lines of the new dark green, which many people probably won't have very much of, and it shows up as an accent color in all of the buildings. The blue from the game is relatively close to the standard Lego blue, if I recall correctly, and I'm sure there's more elements / better availability in blue than dark green.
Thoughts?
I'll go with red for the units I'm working on then. Thank you, I appreciate it. I usually played as red Persians, so I'm going to build a contingent of red Persian War Elephants to knock on the gates of your Tuetonic Fortress.
Laters,
