I... am a moron
I... am a moron
Postby SavaTheAggie » Tue Nov 04, 2003 3:43 am
After starting tests for my new torso template, I decided just for fun to print out a shield too. Well, much to my dismay, the shields aren't the right size!
I am a moron.
While the width of the shields are dead on, I neglected to test the length of my shields (as this was the first time I actually cut out a shield).
I've since begun the long process of re-editing and probably in some cases, re-creating all of the shields so that they will be the right size.
I have also made sure that this time around the horizontal top border of the shields are the same width as the sides.
I will update you all when I have finished editing the shields.
I am such a moron.
Postby Troy T. Moore » Tue Nov 04, 2003 5:05 am
Easy there, buddy! You had a bit of an oversight, definitely not to be confused with being moronic. Irregardless the work that you are doing is VERY appreciated by many if not all here, including myself. Thanks again, and keep up the GOOD, GREAT, STELLAR work. :wink:
Troy T. Moore
Troy T. Moore
Users browsing this forum: Google [Bot] and 1 guest
