Thank you all for your kind words.
Sir Nelson wrote:Have you considered using cheese slopes to fill in the gaps under the roofline?
I hadn't until now, good idea.
Heir of Black Falcon wrote:Is there more inside shots?
Not at the moment, but I'll remedy that when I get around to getting new batteries for my camera.
Bruce N H wrote:but the effect is hurt by also using barrels as barrels a few studs over.
I noticed that after I saw you mention it. Bad placement, since they could have been put anywhere. I probably could have just left them out, actually, but I have gotten addicted to barrels.
Shadowviking wrote:So yeah.
Blogged on the TFOL blog... here's hoping you
are a teen. >_>
I am indeed, for another 10 months. Nice blog, btw.
Black_Walnut wrote:I also liked the construction pics, but where is the second tree?
Indeed, you have spotted a screw-up on my part. When I first took the construction pics as I was putting it together, I only had one tree, and later added the second because it didn't seem balanced. However, to go back and fix the first pictures would have required way too much work, and I'm lazy.
