Excellent work! I've seen canvas specifically intended for ink jet printers, and I've had it at the back of my mind to experiment with this someday - what material did you use for the print?
Outstanding directions. I'd like to see what some of the other customizers come up with for designs.
Sounds like you only lacquer the inside (part that faces the minifigs back), is that right? What color did you use on the inside? No color seems to have bled through. Overall a very successful enterprise, well done.
An idea I came up with for custom shields involves iron-on transfers. Just buy the iron-on transfer printer sheets made for colored fabrics, print out what you want and iron it on where you want. It's probably not as quick/easy/cheap as the printed fabric method, but I had some of the iron on sheets laying around.
I found my ink-jet canvas, but I'm disappointed with the results. The black ink tended to bleed into colored areas, and turning the printer to draft mode to lessen the amount of ink led to faded looking prints. From any normal viewing distance they look okay, so they weren't a complete failure, but my advice is to bypass ink-jet canvas for the purposes of maintaining fine detail. A cleaner, simpler style may work, though.
Hmm ahem, anyway, great design. I wish I could do that. I am not sure if the papercloth would work on our printer. Here is an idea to all those who don't have these matterials. Use normal paper. I have used paper capes, and they work fine. Perhaps they don't look as great as cloth, but they are ok.
