We will likely be hosting some LCs and maybe even a GC centered around a few categories of the CCC that starts November 1st.
Once we know what the categories are, we will be able to better figure out what sort of LCs/GCs will work best with the CCC categories.
What we DO know now is that we will be allowing all CCC entries to be counted as free builds for LCC, provided they meet standard LCC requirements (ie, you should involve your character somehow, the your faction's banner should be included, etc.).
Now, obviously, you may not want your CCC entry to include your figure, have the banner, etc. What I recommend in those cases is to take seperate photos for CCC and LCC. If the CCC category is "Siege", but you'd like your LCC character to be visiting to sell wares or something, just take pics for the CCC and then remove the catapults/troops/etc, and add your figure and faction banner along with short story tying it in to your LCC character.
Since we are allowing all CCC entries as free builds (no limit of 2/mo), each FO reserves the right to reject a CCC entry as a FB if he feels it doesn't fit the above LCC requirements. Also, you can only earn 2 points per category, so if you're like Mark and build two entries for each CCC category, you can only earn FB points for the first entry into each category.
The standard rule for 2 free builds/month still applies for non CCC entries, so if you want/need to use something other than a CCC build to continue your story, you'll still have that option available.
The guild hall rule of "must be built exclusively for the guild hall" still applies, so CCC entries will not be allowed as guild hall submissions.
Fair enough?
